Possible to remove PS Pulley with pump in car?
Car: 1985 IROC-Z
Engine: 383
Hello all,
I've been fighting with my new water pump and while putting everything back together, I managed to have the bolt that holds the PS pump to the bracket (from the front) come all the way out. Not much clearance between this and the pulley and I've been trying to get it back in for hours. I really, really don't want to remove the PS pump from the car to get the pulley off, any suggestions for trying to get it out while on the car? I can get the front nut off easy enough, but the pulley doesn't want to move.
Re: Possible to remove PS Pulley with pump in car?
No problem.
Go to the parts store and "rent" a PS pulley puller/installer set.
Transmission: Pro-built 700R4
With the proper tool, it is actually pretty easy.
Car: 1985 IROC-Z
Engine: 383
Thanks for the info, good to know. But I found an even easier way...
Waited for the wife and her tiny hands to get home from work - took her about 3 minutes to get the bolt threaded in.
Tiny hands also make the _ _ _ _ _ look bigger.
91RSCamaroSteve
LSX and LTX Parts
Feb 2, 2013 05:30 PM
noboostnogo
Sep 8, 2009 05:15 PM
TADailyDriver
Aug 19, 2009 01:58 PM
killacamaro
Apr 21, 2009 08:23 AM
