vortec 6000?
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
For that price I would buy it and sit on it until I found a short-bed, single cab truck to put it in.
I think that engine is LS1 based. If that's the case, you would need all new motor mounts and wiring harness and blah blah blah...
Or you could buy it and drop it in and prove me wrong
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Its not soo bad really we're putting a LS1/4l60e combo into my frineds 88 GTA working the engine moutns in to fit is a pia but it drops in fairly easily, have to get the mounts made up correctly, and thats it pretty much...we are using a aftermarket harness due to some cut factory wiring harness :-( but should be running by next summer :-)
later
ps think you will run into prob using the truck motor intake/tb setup due to the differecnes though
later
darwinprice
17
Oct 11, 2015 11:51 PM
monte87cortez
Sep 26, 2015 08:10 PM
