buddy has a lt1 that he will give me what do i need to make it work
Old Jan 12, 2002 | 02:33 AM
2ponchos's Avatar
like the post says.. what mods do i need to make it work?? who has done this that can tell me.. the only thing that the motor needs is to be freshened up.. will my tpi unit work or would i just use the lt1 stuff.. thanks for any input..
Old Jan 12, 2002 | 06:04 AM
ede's Avatar
ede
it'll bolt right in all you need is the ecm and harness. you'll need to remove you're harness to make it look clean and neat. i don't think you need the trans for the lt1, but if you do use it it is controlled by the ecm too. you ought to be able to find out a lot more doing a search on the motor swap board. good luck
Old Jan 12, 2002 | 06:07 AM
2ponchos's Avatar
thanks ede could u since u are the moderator move this topic over there i didnt even think bout posting there sorry!!
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
