Hey folks,
I've been trying to fix some wiring issues in a 1982 camaro, I've cleaned most everything up, fixed breaks, and rats chewing on the wires. Heat shrink coating/tubing to repair. However, I've found a few wires that I am at a loss with... can't really tell what they do exactly. There is 3 or 4? black wires which have a GRD signal, they are all soldered together to a single black wire that runs into the loom and I'm not sure where...... There are also 3 or 4? grey wires that I'm not sure what they go to either, no GRD or power signal with anything turned on/off etc. If anyone happens to have a diagram of the stuff behind there, or can give me an idea of what they may be for I would appreciate it..... I just can't see the grey wires going to the black wires, unless there's some sort of connector missing.
