Vacuum hose - when is reinforced (rated to 50hg) needed?
Old Apr 20, 2020 | 10:53 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Hi Guys, this is just a general automotive question. Looking over at Rock Auto there are 2 types of vacuum hose to choose from, it appears non-reinforced is generally good to 25-30 hg and reinforced is good to 50 hg.
Are there specific areas of automobiles that are pulling higher than 25 hg? Wondering what reinforced would be used for?
Thanks for your insight!
Old Apr 20, 2020 | 11:14 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Vacuum hose - when is reinforced (rated to 50hg) needed?
Reinforced is always a good idea. I have seen some stock engines suck the cheap stuff closed especially where high engine compartment temps are normal. Perfect vacuum is just over 30 in/hg.
Old Apr 20, 2020 | 11:49 AM
LiquidBlue's Avatar
Transmission: MD8
Thanks. I was looking at this a little closer, and the temp ranges and vacuum ratings on reinforced and non-reinforced are about the same. the reinforced seems to come in bulk, causing it to be much more expensive.
repairguy101
Jan 14, 2018 01:57 PM
MaroonBerlinetta
Sep 22, 2006 07:49 AM
nj88v6
Dec 26, 2001 08:25 PM
