Can an inline fuel pump be installed with stock pump?
Old Jan 15, 2002 | 10:42 AM
Brandog87GTA's Avatar
I am using a mallory 3 port regulator and am going to run nitrous, Can I just unplug the intank pump and run an in line holley blue pump???? Or will it inhibit flow?
Old Jan 15, 2002 | 10:59 AM
tpi_roc's Avatar
Most people remove the stock pump, and put in a mechanical pump vehicles pick up tube
Old Jan 15, 2002 | 07:32 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Can an inline fuel pump be installed with stock pump?
the way NOS sells their kits they use an inline pump and the stock pump. that way there will be enough volume when using the n2o. you cannot pull through the pump in the tank. it is a positive displacement design. will not let anything through without it turning.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
