cruise control linkage?
Old Oct 7, 2020 | 06:25 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
I believe this is the cruise control linkage, but where does it connect to? Do I have to put this on the same area as the throttle linkage? Also, what is that one cable on the top of the throttle body with the black end?
Old Oct 20, 2020 | 11:36 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: cruise control linkage?
The currently connected cable at the top is for the transmission TV. The other is the throttle cable
The cruise cable connects on the inside of the bracket, I can just see the clip in your picture where the linkage goes
Old Oct 28, 2020 | 10:00 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
The TV cable is on the wrong side of the lever it should be on the inside and the cruise cable goes were you have the TV cable.
RS Vert 91
Jun 14, 2010 10:14 PM
sancho
Dec 17, 2007 12:22 AM
Scotty562
Jul 11, 2006 06:24 PM
therckid
May 1, 2004 11:35 AM
