1988 IROC 5.7l crank no start
Hi Everyone. I am having a problem getting my IROC started. Its 5.7l TPI and it cranks but no start. I have changed the fuel pump out and the fuel pump relay. Still only says 20 psi fuel pressure. I have checked the fuse located on the inner fender near the battery and all was good. I have tried testing the pump by jumping the ALDL and the pump kicks on although when I turn the key forward, the fuel pump doesnt kick on. Any suggestions on what to test next? Oh and forgot to add that it will start with a shot of starting fluid. Definitely fuel related.
Car: 1991 Pontiac Firebird Formula
Engine: 5.0L 305 TPI
Transmission: 700R4 MD8 Automatic 4Spd.
Re: 1988 IROC 5.7l crank no start
Hey Tyanez, Is your car equipped with a VATS Security system? Should be able to tell by looking at the ignition key. If it does it will have a black rectangle with rounded ends (Stadium) with a silver line in the center. If this is present, You may have a faulty lock cylinder or bad wiring to it. If this system has experienced a failure it will isolate the fuel pump relay via the ECM and it will not send fuel to the engine for starting.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
vats will not kill fuel pump relay control. what year is this ? The ecm controls the fuel pump relay for prime on the relays green/white wire.
Thanks for the replies. I do believe it is equipped with VATS. A couple other things I may add I replaced the ignition control module and the fuel pressure regulator this weekend. Still the same. Could it be possible my ECM went out? I was able to read the codes and it is reading code 54, low voltage to the fuel pump. Not sure what next to test and hate having to keep guessing by replacing parts. Also, when I do crank the engine, after I stop cranking I can hear return fuel going back into the tank.
C54 Fuel Pump Circuit Low Voltage.
The status of the fuel pump signal (Circuit 120) is monitored for voltage by the Engine control module, and is used to compensate fuel delivery based on system voltage. This fuel pump signal is also used to store a trouble code if the fuel pump relays is defective or the fuel pump voltage is lost while the engine is running. There should be about 12 volts on Circuit 120 for 2 seconds after the ignition is turned "ON" or any references pulses are being received by the Engine control module. Code 54 will set, if the voltage on Circuit 120 is less than 2 volts for 1.5 seconds since the last reference pulse was received. This code is designed to detect a faulty relay, causing extended crank time, and the code will help the diagnosis of an engine that "Cranks but will not run." If a fault is detected during start-up, the "Service Engine Soon" Light will stay on until the ignition is cycled off. However, if the voltage is detected below 2 volts, with the engine running, the light will only remain on while the condition exists. (Code 54 for 5.0L (VIN F) & 5.7L (VIN 8) "F" Cars, Page 6E3-A-58 Of Dealership service manual for 1988 Chevrolet Camaro)
I Also have the trouble chart for this code, I'll upload that next.
Yes there is a wiring diagram, I'll take a picture of it and upload it as soon as I get home (Around 6:30pm EST USA)
So I am getting a little closer. I replaced the pigtail to the fuel pump relay along with the relay and now the pump kicks on when I turn the key forward. Although I have the fuel pressure tester hooked up and its not even getting 20psi. I disconnected the fuel line and I see fuel coming out in a steady stream but not a strong flow. Its like barely turning on a water hose. Anyways. I have already replaced the pressure regulator too. Same. Any suggestions on what to check next. Remember that the fuel pump, sending unit, and fuel filter are all new too. Thanks in advance.
This pump is a Delphi CFE0110 from Autozone and it it shows its rated at 58psi. The one before it was an AC Delco brand new. Did the same. Only about 20 psi, so thats why I pulled the tank back down and put in the Delphi. So thats what is bugging me. I surely dont want to pull the tank down again if I dont have to.
New parts:
gas tank
sending unit
fuel pump
fuel filter
fuel pump relay
fuel pump relay pigtail
new battery
New parts:
gas tank
sending unit
fuel pump
fuel filter
fuel pump relay
new battery
I'd wanna check and make sure I had good voltage back at the pump. Like verified at the pigtail under the car, not under the hood at the relay. ...I'd also wanna confirm pressure coming OUT of the pump as close to the pump as possible. You could have a kink or blockage in the line somewhere.
Thanks for the reply. I checked the voltage at the connector where the pump plugs into and with the key forward its 12 volts and when you crank the car it goes to 11 volts. I checked for kinks and I dont see any at all.
any recommendations on a pressure tester that I can hook up in line close to the fuel pump?
gregmy123
May 20, 2026 07:47 AM
