AFR 195, what PN for L98 and Dyno Don Headers
Old Mar 9, 2021 | 09:25 AM
Shinobi'sZ's Avatar
There are a few different options for the 65cc AFR 195 Heads and spark plug holes. It looks like there is a 1034 (straight), 1040 (angle), and 1041 (angle). I found another thread regarding Dyno Don Headers and spark plug angles, it looked like there was some confusion as to whether straight plugs worked better than angle plugs on that thread, then there was talk of L98 angle plugs. AFR from what I can see on the website only comes with straight or angle plugs. Just wondering if anybody knows the correct AFR head part # that would go with Dyno Don headers?
Old Mar 9, 2021 | 03:21 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: AFR 195, what PN for L98 and Dyno Don Headers
They work with all heads but best with angle plugs.
Old Mar 9, 2021 | 04:01 PM
Shinobi'sZ's Avatar
Thanks Don...just ordered the 1040s with angle plug.
Old Mar 9, 2021 | 05:53 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
If you are running 1040's, with Don's headers, you will absolutely need a stubby spark plug socket. Plug changes are easy, there's just no room for a regular sockets.
Also, get Remflex 2017 header gaskets. Many of the other gaskets recommended cover up part of the afr ports. The remflex's match the header and the cylinder port perfectly.
Old Mar 10, 2021 | 07:58 AM
BOTTLEDZ28's Avatar
Transmission: A4
I ran into this issue on my last car. I coudnt find AFR heads in L98 angle....which at the time was the style to use with the SLP headers I was running. Im running stock heads on my current car now.
I'm running the metal 4th gen LT1 spark plug boot protectors on my car with DD headers. No issues at all. They help keep heat away from the boots.
LilJayV10
Jun 27, 2022 07:14 PM
1989GTATransAm
Dec 16, 2007 12:44 AM
Z RATED IROC
Oct 15, 2007 02:23 PM
