Vacuum loss at idle
Old Aug 26, 2021 | 01:26 PM
caddyescalade's Avatar
Vacuum loss at idle
I have a vacuum loss at idle, when I increase throttle the vacuum goes up. It would appear that the loss of vacuum is coming from my vacuum advance on the distributor, when I plug it off i gain vacuum at idle.
im assuming this is wrong, as I’ve always been under the impression you should have the highest vacuum at idle. The vacuum advance shouldn’t take away vacuum should it?
any suggestions?
Old Aug 26, 2021 | 01:48 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Vacuum loss at idle
Suck on the port coming off the vacuum canister. If you stop it with your tongue and it doesn't maintain the vacuum, it's bad.
Token
Carburetors
85
Jun 24, 2024 01:47 PM
matts86cam
Mar 5, 2012 09:31 PM
91 camaro racer
Oct 2, 2007 01:10 AM
Saigon_Bob
Sep 6, 2007 07:29 PM
86TransAMsbc305
Dec 1, 2003 04:40 PM
