Firebird 3.1 Purge Valve resistance
Old Sep 13, 2021 | 03:14 AM
aycaramba's Avatar
Car: '1991 Pontiac Firebird
Engine: LH0 - V6 3.1
Transmission: TH700R4 automatic
Hello guys,
I have issues with my Firebird idling rough. We have replaced the TPS, the coolant sensor, MAT, Delphi IAC, Fuel Injectors, Ignition Coil / cables, O2 sensor, EGR valve and many other things. Then we checked the EVAP canister valve. I have two canisters and both of them show a strange resistance behaviour.
Measuring the resistance between the two terminals it starts from approx. 1200 Ohm and keeps decreasing while measuring for just a few seconds to ~300 Ohm and lower. I have read somewhere else that the Purge Valved should be around 20-30 Ohm. Is there any varistor causing this, or are both of the valves completely out of service.
Engine is a T-Code 3.1 (LH0)
Last edited by aycaramba; Sep 13, 2021 at 06:58 AM. Reason: Added some more parts which were replaced.
Old Sep 15, 2021 | 04:02 AM
aycaramba's Avatar
Re: Firebird 3.1 Purge Valve resistance
Update:
After using another Multimeter the resistance showed up a value around 30 Ohm, which seems to be okay. Thread can be closed.
Thx.
RVGuy
Jan 26, 2020 11:35 AM
Rob 97 Z28
Sep 2, 2009 10:24 AM
mnovajov
Mar 3, 2003 06:34 AM
c55
Nov 2, 2000 08:19 PM
