Exhaust Manifold Gaskets
Old Feb 8, 2022 | 02:47 PM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
1984 T/A 305 v8
questions- did this engine come from the factory with or without gaskets?
If with, were they one piece steel, or one piece gasket material , or 3 pieces gasket material?
Old Feb 8, 2022 | 03:15 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Exhaust Manifold Gaskets
No Gaskets
Old Feb 8, 2022 | 04:58 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
These cars didn't have them but I'm running them. I hope I don't regret it later...
Old Feb 8, 2022 | 05:57 PM
As GT said, the factory used no gaskets.
Best procedure is to file the heads & manifolds flat, and use no gaskets, if possible.
Sometimes when something is too farkled to restore that way, the gaskets can help. More often than not though they're just another potential failure point. In a way they turn maintenance-free manifolds into having one of The Header Problems: the need for monitoring and occasional retightening.
Old Feb 8, 2022 | 08:11 PM
72buickgs's Avatar
Car: 1984 Trans AM
My car has only 21000 miles, but I have to remove the intake & exhaust manifolds & the rocker arm covers & the waterpump to refinish. Not one of the previous owners (father & daughter) & the fellow that I purchased the car from dared to take car of the car nor maintain it. I do not expect any warpage of the exhaust manifolds but I will check for trueness. These jobs are for the spring.
Tkx for the information...
BluFBdy
Nov 5, 2007 12:44 AM
2.8RS
Jul 23, 2007 06:19 AM
Chevyman84
Feb 26, 2007 09:18 PM
rv1890
Sep 27, 2006 05:54 PM
1986CamaroSC
Jun 13, 2003 12:25 AM
