Odd ignition issue
Old Mar 25, 2022 | 01:31 PM
Clemson327's Avatar
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
Odd ignition issue
So I have an odd one, and I’m wondering if anyone else has seen this before.
I cranked up my car this morning after changing the springs under the rotor to slow the advance curve, and I noticed a miss immediately. I put a timing light on it to verify it after the spring change, and I had zero signal from #1. I checked other wires, and all had spark. When I removed the #1 boot from the distributor, it would spark an inch+ into the boot, and the cylinder would start firing. Once I put the boot back on, no spark.
In short, the #1 cylinder only sparks when the spark plug boot is not fully seated on the distributor cap. Once pulled away from the cap, it shows a strong spark.
Old Mar 25, 2022 | 01:48 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Odd ignition issue
Compare the inside of the boot on the #1 wire to another wire. Sounds like something is up with the connection.
Old Mar 25, 2022 | 02:53 PM
ULTM8Z's Avatar
deleted...
I misread the post and my earlier statement doesn't apply.
dangelsaurus
Nov 24, 2021 01:45 PM
HawkForum6
Apr 24, 2021 04:48 PM
Jlanz55
Sep 9, 2015 09:09 AM
Eggplant Jeff
Sep 27, 2004 05:16 PM
Damien00677
Sep 6, 2003 11:03 PM
