Ported tpi air
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Ported tpi air
Should the minimum air setting on a ported top end TPI be the suggested stock setting of 450rpm, or should it be different?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Ported tpi air
Might be slightly low , use iac count set to 20-25 step engine warm.
