350 Vortec stumbles on acceleration and “hangs”
Old Dec 31, 2023 | 11:34 AM
92z23's Avatar
Car: 1991 RS
Engine: L03 305
I’ve got a 92 RS Camaro with a 98 L31 vortec swapped in with a tuneport. Here recently, it’s had a hard start and has a stumble on throttle application and likes to “hang” when it revs down. It used to be real snappy and quick, but now it acts like it wants to fall on its face. I had 4 plug wires off the other day and mistakenly fired it up while they were off, I quickly shut it off and fixed the firing order, but since then it’s ran horrible. Would this be a possible timing issue? Or something else.
Old Dec 31, 2023 | 11:36 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: 350 Vortec stumbles on acceleration and “hangs”
I mean, this may seem obvious but, did you put the wires back on in the right order?
Old Dec 31, 2023 | 11:37 AM
92z23's Avatar
Car: 1991 RS
Engine: L03 305
I did, double checked it today when I started it up.
Old Dec 31, 2023 | 12:23 PM
ULTM8Z's Avatar
Also probably need to think back carefully about everything you did. If it was running good before, something obviously changed.
Did you take out any of the plugs? Possibly cracked a ceramic body? Are the plug wires touching exhaust and maybe got damaged?
Example of something stupid... one time i pulled a plug out an accidentally dropped it. Ceramic looked ok but I didn't notice that the electrode gap nearly closed due to the way it evidently hit the ground. Didn't realize it until I put it back in and noted the misfire, prompting me to remove the plug again, at which point I found it.
Old Dec 31, 2023 | 08:46 PM
92z23's Avatar
Car: 1991 RS
Engine: L03 305
none of the plugs were removed, just the ends from the cap were removed. I’ll check them tomorrow and check back.
Old Jan 1, 2024 | 06:34 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
ecmagee1984
Dec 23, 2005 08:20 AM
1bad91Z
Aftermarket Product Review
22
Jun 3, 2003 09:53 AM
steve8586iroc
Apr 29, 2002 11:31 PM
3.8TransAM
Mar 9, 2002 01:19 AM
