More horse power needed
Hello im looking for some advice on adding more horse power to a new crate Chev 350/357 hsp. Where and what's your thoughts..
As the latest in Chevrolet Performance’s Street Performance crate-engine lineup, the SP350/357 is designed as an affordable performer to match just about any budget. Better still, it uses strong components and modern technology to make it a better alternative to rebuilding. The SP350/357 leverages the strength of a strong rotating assembly secured in a brand-new block with four-bolt mains, and matches it with modern valvetrain technology to support high-rpm capability.
Horsepower
357 HPTorque
407 LB-FTTech Specs
Engine Type: Chevy Small-Block V-8
Displacement (cu. in.): 350
Bore x Stroke (in.): 4.000 x 3.480
Block (P/N 10105123): Cast iron with 4-bolt main caps
Crankshaft (P/N 10243070): Nodular Iron
Connecting Rods (P/N 10108688): Powdered metal
Pistons (P/N 88894280): Cast aluminum
Camshaft Type (P/N 12677151): Hydraulic roller
Camshaft Lift (in.): 0.473” intake / 0.473” exhaust
Camshaft Duration (@.050 in.): 215° intake / 223° exhaust
Cylinder Heads: Cast iron; as cast with 64-cc chambers
Valve Size (in): 1.940 intake / 1.500 exhaust
Compression Ratio: 9.0:1 nominal
Required Fuel: Premium
Maximum Recommended rpm: 5600
Re: More horse power needed
What car is this going in? What else has been done to the car to support "high performance"? Gears, converter, exhaust system, ??? What induction system is going on it? What intake manifold does it have?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
In today's market, it would be easier, cheaper more cost productive to drop in a 4.8 or 5.3 LS engine
Be aware, this is a REAL engine, not like imports, where you buy this fart can muffler and it "adds" 15 HP, that cold air intake and it "adds" 25 HP, some tune and it "adds" 20 HP, some kinda krome something or other and it "adds" 10 HP, and so on; so when you get done with all that, you've DOUBLED your original 90 HP, butt still aren't going any faster, except by way of weight reduction, concentrated at the center of the owner's wallet. Can't imagine how that could happen.
Detroit locker with 342 gears
dual exhaust
long tube headers
dual plane RPM intake
dual cold air intakes
Electric, holy fuel pump, and regulator
650 Holley
3000 stall converter
Electric fan
Holley high flow water pump
it's going in 1958 Chev Apache truck
dual exhaust
long tube headers
650 Holley
Electric fan
Car: 94 GMC K2500
Engine: 383, Vortec heads
Transmission: 4L60E, 4.3L Torque Converter
Axle/Gears: 3:73
Wrong post
