Gas Tank Unfillable
Old Feb 4, 2024 | 08:39 PM
Devn's Avatar
Car: 1987 Firebird Formula
Gas Tank Unfillable
Sorry if this is the wrong place for this question. But I'm having an issue with filling my gas tank when I get to half a tank the gas pump will shut off and if I keep trying to fill it it shoots out of the filler neck which is annoying and embarrassing but very funny to your buddies in the car.
Anyway I crawled under the car and removed the vent valve and I was able to suck air and blow air through it. I also tried getting gas with it off and the problem persisted. I also made sure the gauge is working correctly by unplugging the sending unit and the gauge read empty then used a paperclip to see if the gauge read full which it did. Also If I let the gauge hit empty it is definitely empty learned that one quick.
Forgot to say it a 87 305 TPI Firebird
I can't really tell if it's a pressure problem it could be. Occasionally when I take the filler cap off I can hear pressure releasing but it's not often that it does that. If anyone has any pointers please let me know.
Last edited by Devn; Feb 4, 2024 at 08:45 PM. Reason: Forgot to say what car it was
Old Feb 5, 2024 | 02:50 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: Gas Tank Unfillable
I have heard of that problem with aftermarket fuel tanks. The only solution I have read is to fill the tank very slowly, just barely depressing the fuel nozzle trigger.
Good luck,
Fred
Old Feb 6, 2024 | 09:29 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
is the vent line clear and moving air?
Old Feb 6, 2024 | 12:29 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Anther item to check, is to see if the filler neck has been cut. Then patched with a piece of hose. Many of these tanks have a channel to allow air out of the tank, while fuel pours in. This is done via a piece of sheet metal mounted in the neck, like a two-tired bridge.
Open up the bridge between the tiers and all heck breaks loose.
RBob.
dstack18
Jan 24, 2011 10:45 AM
jayk2k3
May 23, 2009 10:01 PM
86birdHT
Sep 3, 2005 03:06 PM
SilverSub122
Feb 12, 2003 10:09 PM
86FirebirdV8350
Jan 19, 2003 08:15 AM
