Help with two sensors. 85 Camaro
Old Apr 8, 2024 | 08:16 AM
Dad9904's Avatar
Car: 85 camaro z28
Engine: 83 305 casting uck
Axle/Gears: Unknown
I have two sensors that I’m not sure they serve a purpose anymore and would like to delete them if they are no longer needed or if they are make sure they are wired correctly.
first is a cylinder shaped sensor has three vacuum ports sits on a bracket front of the motor by alternator .
second is in the intake has a green top and two spots for connectors. Screws into the intake front left. I’ll post a picture.
Old Apr 9, 2024 | 11:20 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Help with two sensors. 85 Camaro
Both of them control the fuel tank charcoal canister vapor purge.
gbettner
Mar 31, 2013 05:30 PM
85Camy
Jul 12, 2008 02:29 AM
johnyIROC
May 19, 2004 12:37 PM
Ben87GTA
Jul 24, 2001 01:54 AM
