No Fuel New Everything
Old Aug 2, 2024 | 09:20 PM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
Transmission: 700r/manual
hey yall, im stumped and feeling defeated. So its a carbed 350 used to be a tbi 350, it was running great then one day it shot gas everywhere out the carb randomly it seemed. I rebuilt the carb 1406 new pressure regulator, new filter, new fuel pump still no fuel. Read about the oil pressure switch the other day thought that could be it replaced it still no fuel, pump comes on primes but doesnt send fuel. What else could it be? could the oil pump cause this?
Old Aug 2, 2024 | 09:54 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: No Fuel New Everything
presuming you are only using the electric in-tank pump,polarity could be wrong on new pump and running backwards.
Old Aug 2, 2024 | 10:12 PM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
it is the intank electric pump but the old one was doing the same thing, come on and prime then not send i used a delphi cfe0115
Old Aug 2, 2024 | 10:48 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Sounds like you hooked the pump up incorrectly.
Old Aug 3, 2024 | 08:07 AM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
it was a direct replacement i dont see how you could hook it up incorrectly. Since the previous pump was doing the exact same thing i dont think the fuel pump itself is the problem im looking for reasons outside of a defective pump why it might not send fuel like a bad oil pressure switch or fuel pump relay. Maybe vats?
Old Aug 3, 2024 | 10:43 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
If fuel pump is heard,there is pump or plumbing problem,nothing electrical outside of the tank.If this situation gets to be trouble,you could mount a regular engine -driven fuel pump.
Old Aug 3, 2024 | 10:46 AM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
ill pull it one more time and inspect it but maybe external would be good idea, so i just want to make sure nobody thinks its a oil pump issue
Old Aug 3, 2024 | 11:05 AM
ULTM8Z's Avatar
If you suspect the oil pressure switch, simply pull the plug off it and jumper the terminals for a test.
Old Aug 3, 2024 | 12:03 PM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
no i was saying that as a reference about the oil pump switch i replaced it i just meant was there anything else that could cause it BUT 8t2 z-chev you were right i spliced/swapped the purple and black wires to the pump and shes back up and running why did delphi do that though thats so dumb many thanks yall hearing her crank up was music to my ears
Old Aug 3, 2024 | 02:38 PM
Vader's Avatar
Bear in mind that the oil pressure switch is a redundant path for the fuel pump relay, in case the relay fails. Unlike a Ford, it is not a pump cutoff.
The system will work just fine without the oil pressure switch IF the relay is intact. If the relay fails, the pump will only run after the engine is cranking and achieves at least 7 PSI oil pressure.
I suspect there is a problem with the pump relay and/or its wiring.
Old Aug 3, 2024 | 03:58 PM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
that makes sense cause even though i got the fuel pumping it didnt explain what caused it to started acting up in the first place
taguy16
Carburetors
Oct 17, 2023 11:23 AM
urbanhunter44
Carburetors
Feb 23, 2008 07:54 PM
jayk2k3
Aug 13, 2005 11:19 AM
pablofour20
Mar 22, 2003 09:56 PM
Dolph88sc350TPI
Jan 5, 2003 05:54 AM
