What is this Valve for?
Old Sep 14, 2024 | 08:52 PM
Isaac_88's Avatar
I have an 88 firebird gta and I was looking at some vacuum lines (pcv etc.) and I noticed these two valves (see the image I attached). The one that is plugged right now I know is for the crankcase vent hose for the pcv system but I can't seem to find what the open one underneath it is for. Is it a vacuum line? I have two vac hoses from the purge canister that I need to attach to a vacuum (purge vac and vac control), can I tee them and put them there?
Thanks in advance for the help.
Old Sep 14, 2024 | 10:15 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: What is this Valve for?
I'm guessing it would help you a lot if if took a bunch of detailed under hood & engine pictures of a 7k mile bone stock original 1988 GTA. If I can remember it I'll try to do it tomorrow. Or they might be pictures of a 1989 GTA. I'm installing driver & passenger side molded PCV & CCV hoses, PCV valve and valve cover grommets, setting the minimum idle air bleed adjustment and TPS voltage, setting the base timing, and installing a 4 wire heated O2 sensor.
I'm probably going to do it tomorrow, but I'm lazy and I might not and if it's hotter than a well digger's azz I for sure ain't.
Old Sep 14, 2024 | 10:36 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
It goes to the charcoal canister over by the airfilter canister.
Old Sep 15, 2024 | 02:33 PM
Isaac_88's Avatar
I have two vac hoses from the charcoal canister. I don't know why they are separate but can I just tee them and hook them up to that valve?
Old Sep 15, 2024 | 02:34 PM
Isaac_88's Avatar
"I'm guessing it would help you a lot if if took a bunch of detailed under hood & engine pictures of a 7k mile bone stock original 1988 GTA. If I can remember it I'll try to do it tomorrow."
That would be incredibly helpful thank you.
Alexstone0429
Mar 15, 2024 04:22 PM
george88gta
Jan 9, 2023 11:39 PM
mgray1982
Sep 27, 2008 01:39 PM
ghettocruiser
Sep 22, 2006 07:58 PM
1981LT1
Mar 27, 2006 08:40 AM
