Windshield Washer Pump
Old Jan 23, 2002 | 10:37 PM
VampireHunterC's Avatar
Is there a fuse for the windshield washer pump? My pump is not working, and I don't see any fuse labeled for it. I don't want to pull the pump if it is only a fuse.
Old Jan 24, 2002 | 09:54 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I don't believe so. I think it runs off a common fuse for something else.
I've gone through a number of the ones that mount on the wiper motor. Something just causes them to burn out (probably sucking too much air). I've found so far that the cheap aftermarket on eI bought at Trak Auto (Anco brand I think) has lasted far longer than the GM originals.
Old Jan 24, 2002 | 11:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've replaced both the front and rear pumps (rear wipper).
JamesC
Old Jan 24, 2002 | 11:46 AM
Z28DJP1987's Avatar
Engine heat and lack of use will result in the pump drying out and not working. I have replaced mine and make sure to use the washers once a week with no problems.
Old Jan 24, 2002 | 11:48 AM
99Hawk120's Avatar
I lived in blacksburg VA at the time, using the washer constantly was not a problem.
Neither was engine heat.
The pump simply lost its prime too easily and as a result had to work too hard to get the fluid pumping back through it.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
LittleFranks
Sep 17, 2015 12:22 PM
Randomtask2
Aug 26, 2015 03:34 PM
kyleb24
Aug 15, 2015 08:24 AM
