Wipers
Old Mar 26, 2025 | 09:04 AM
Jaxbeachdawg's Avatar
Car: 91 Camaro
Wipers
Wipers weren't working after sitting up for a year or so,turn them on at the switch,got out and bumped the blade arms started working,is there a trick I can use to keep them moving,or a switch issue? 91 rs
Old Mar 26, 2025 | 09:59 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Wipers
Grease up the joints and take it for a long drive in the rain.
Old Mar 26, 2025 | 12:13 PM
Re: Wipers
It's just an old crude DC motor with a commutator and brushes and all that. Very Stone Age. What you describe is a VERY common failure mode for those.
Sounds like most likely, the brushes and commutator got corroded up where they were sitting together, and made a "flat spot" in the motor.
Do what Komet suggested: grease the joints in the transmission real good and just run it. If all it was is some corrosion, just running it for awhile may well clean it off to where it doesn't ever do it again.
Mick Keinedaten
Jul 4, 2022 04:28 PM
Matillac
Feb 13, 2021 08:33 AM
91 RS Drop Top
Interior Parts Wanted
Oct 5, 2009 07:43 PM
SDTransAM
Dec 1, 2007 04:32 PM
warrior_91
Mar 6, 2004 03:12 PM
