Help identifying part on throttle body
hello all. My engine has been running extremely rough and hesitating on acceleration. I see this wire/hose is disconnected and I was wondering if this could be the cause and if so what it’s called to replace it. The connector piece is on the throttle body and it ends up behind the EGR valve. Thanks!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Re: Help identifying part on throttle body
It’s a friction fit or can adhere with rtv or glue
Joseugaz
May 23, 2022 06:39 AM
iroc90dfi
May 19, 2015 07:05 PM
