SOLVED: 88 Iroc won’t start after installing center console.
Old Jul 20, 2025 | 04:40 PM
IrocJoe1988's Avatar
Car: 1988 Iroc
Engine: 5.7 tpi
I have been redoing the interior in my 88 Iroc. Auto 5.7. It started/ran fine until a couple of hours ago. I was putting the center console back in and when I was finished, it won’t start. The key turns, all electronics run, but I get no crank/no start. What did I do to this crazy thing?!
Old Jul 20, 2025 | 04:59 PM
NoEmissions84TA's Avatar
Re: 88 Iroc won’t start after installing center console.
Check the switch and connector on the side of your shifter.
Old Jul 20, 2025 | 05:48 PM
sscooter's Avatar
Car: 86 trans am
Engine: 383 w true duals
Transmission: t56
check the neutral safety switch under the center console. the yellow and purple ones specifically are the neutral safety wires. maybe it got unplugged??
Old Jul 20, 2025 | 05:54 PM
Car: 1988 Iroc
Engine: 5.7 tpi
I’m an idiot. You guys are right, it was the neutral safety switch. I must have snagged it somehow putting the console back in. Fired right up, thank you!
johnny89345
Jul 21, 2009 08:52 PM
jacobmh
Oct 27, 2007 12:44 AM
crazymonkey88
Nov 24, 2005 05:49 AM
