#059 305 58cc L30 Vortec heads on a stock 75 400sbc?
Car: '88 IROC T5 Vert ‘13 Vette
Engine: 305 TBI
Axle/Gears: 3:08
Hello sofa, fast355, Orr, et al
Can #059 L30 305 Vortec 58cc heads with steam holes drilled be used on a stock 76 #509 400 sbc short block with 93 pump gas for street use?
Stock cam, adequate radiator, outside air intake, #1014 gaskets, & adjusted timing would be addressed. Initial look tentatively has the pistons .025 in the hole.
The stock pistons have a circular dish with slight valve reliefs.
I have found that the piston dishes could be 18 cc 22 cc in volume.
Also, instead of the usual VIN stamping deck boss below the front of the passenger cylinder head, theres a very short square blank block devoid of any numbers.
it does not appear to be decked at all.
Maybe because its a dedicated RV 400 small block.
Would this head/block combination detonate itself to death or have a chance of living on the street with occasional spirited driving?
Re: #059 305 58cc L30 Vortec heads on a stock 75 400sbc?
It'll fit and run and all that. As far as the compression being within range, ... that's gonna be kinda tough, butt depending on tuning, it might work.
It's been decked. Blee dat. Probably, just a real long time ago.
Engine: 305 TBI
Axle/Gears: 3:08
Thanks for the reply sofa, appreciate that.
The 400 is from a 42K mile RV. Two of the 12 exhaust manifold bolts broke off at the number one cylinder exhaust port after soaking all of them in Aerokroil for a week and a half before the attempt.
xlwhellraiser
Jun 4, 2005 12:13 AM
