5.5L from a 305?
Old Sep 15, 2025 | 11:31 AM
Vhanta97's Avatar
Car: 1984 Camaro Berlinetta Starship Ed.
Engine: Worn out SBC 305 5.0L V8
Axle/Gears: Stock
5.5L from a 305?
So I've got a spare 305 just sitting around and I'm trying to decide what to do with it. I know that the only major difference between a 350 and a 305 is the bore size. Google isn't much help on the topic so I'm wondering, is it possible to make a 305 have 5.5l of displacement, and if so/not so, how would I go about getting that target number? Just out of curiosity of course. I'm assuming bigger CC heads, a bigger stroke and boring the block out as far as I safely can, but what else should I do to get that number?
Old Sep 15, 2025 | 01:01 PM
codyman125's Avatar
Car: 1989 Firebird
Engine: 2.8 Liter V-6
Re: 5.5L from a 305?
The 305 (5.0) and 350 (5.7) share the same stroke, the bore is the only difference. A 305 block can not be bored into a 350 block due to cylinder wall thickness. A 305 can be stroked into a 335 (5.5) by utilizing the same stroke that would have been used on the 400 (6.6) much like the ever-popular 383 uses a 350 block and a 400 stroke. Building out a 305 for the cost and money into... still not even a 350... doesn't make a world of sense to me, but you're not me and the kits exist, so go wild.
Here's a kit to do what you're asking about. https://cnc-motorsports.com/eagle-13...h-pistons.html
Old Sep 17, 2025 | 12:33 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Find a way to get it to rev and flow to 8000 RPM and you got a winner!
Old Sep 17, 2025 | 02:43 PM
sodak's Avatar
Car: 1985 iroc
Engine: 416 ls3
Transmission: t65
Axle/Gears: Ford 9"moser 31 spline 350 gears
Power Nation made a stroker out of a 305.. 337 .. made good power like high 400 to low 500 hp.
Old Sep 17, 2025 | 06:33 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Yes, but you'll have to stroke it.
Largest bore and stroked is 5.6: 3.796 max bore x 3.75 stroke = 339/5.6
Largest bore not stroked is 5.2: 3.796 max bore x 3.48 standard stroke = 315/5.2
Stroked not bored is 5.4: 3.736 standard bore x 3.75 stroke = 329/5.4
Typical .030 over bore not stroked is 5.1: 3.766 bore x 3.48 standard stroke = 310/5.1
Typical .030 over bore and stroked is 5.5: 3.766 bore x 3.75 stroke = 334/5.5
Power Nation and its new Engine Power channel have done impressive 305 builds, including a series with comparable builds of a Chevy 305 to a Ford 302, and the results were excellent and nearly equal.
Jayson_305
Apr 2, 2023 10:59 AM
xunedeinx
Dec 19, 2005 03:52 AM
USMC3782
Apr 12, 2005 12:26 PM
vortech305
Mar 23, 2005 07:31 AM
techniqu3
Sep 15, 2002 10:04 AM
