Location of Gear Lubricant filler in Rear End...
Old Jan 29, 2002 | 12:45 PM
bzznczzn's Avatar
Where is the location on the rear end where you add gear lubricant? I haven't been able to take too good of a look, but didn't see it. I have an 87 Formula 350 with a 3.27 posi rear end. I was told it's the borg warner 9 bolt, but once again, haven't been able to take a look, because I am not near the location of my car. Any help would be greatly apreciated.
Old Jan 29, 2002 | 12:48 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
It should be the same as mine it's on the passenger side about the middle of the pumkin.
Old Jan 29, 2002 | 05:39 PM
simon's Avatar
I have the same rear and was told the same thing from the counterman at NAPA. But go ahead an take a look for yourself, its not there. Its different then the standard 10 bolt rears most of the 3rd gens came with. Just pry out the rubber plug in diff cover to fill. I went ahead an picked up a new one at the dealer for $2 as mine was old and brittle. If that little bastard every popped out on trip - kiss your rear goodbye - pun intended. Let me know if you have any more questions.
Old Jan 29, 2002 | 07:19 PM
bzznczzn's Avatar
I thought i was going crazy when i didn't see it. I figured it was that rubber thing, but didn't want to mess with it until I was sure. Thanks for the help.
Old Jan 29, 2002 | 10:16 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
I put a little bit of silicone sealant on mine when I stuck it back in so it wouldn't leak or fall out. If the vent isn't plugged it shouldn't blow out. The vent is on top of the axle tube.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
