routing canister plumbing
Old Jan 31, 2002 | 09:59 AM
silentneko's Avatar
hey guts what would happen if I ran the hose from the charcoal canister straight into the front of the carb. and ripped out the rest of the plumbing and that little box sensor or switch. would my car flood or blow up. what if I kept just that switch in place. any ideas. I need to clean up my engine bay so I can see what I'm doing
Old Feb 1, 2002 | 12:12 AM
Vader's Avatar
Silent,
The EVAP canister also connects to the tank pressure control valve on many models and years. You really need to keep all the plumbing in place to make sure the system works correctly.
You could reposition the lines and hoses in a more orderly manner, clip them togehter with clamps or wire ties, or route several of them togehter in a corrugated tube or braided cover for a more custom look.
You could also move the control valve closer to the canister and off the engine to remove clutter, and run only the purge line to the carburetor and the vacuum line from the TVS to the control valve.
Old Feb 1, 2002 | 09:07 AM
silentneko's Avatar
so I can justreplace the hoses and hide it over by the can. thats not a bad idea I supose, I'd still rather get rid of it. but for now this can work.
F-body-fan
Jan 12, 2023 01:49 PM
ZZ3Astro
Aug 13, 2019 12:57 AM
Quzyle
Oct 15, 2015 03:35 PM
88CamZ
Oct 8, 2015 10:29 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
