Computer controls timing?
Old Feb 2, 2002 | 10:05 PM
JAY87GTA's Avatar
Here's my problem. At idle and light cruise I get an occasional stumble or like a buck. Under power it's fine. Well I checked the timing tonight after cruising around, and it was at 36 degrees, which is close to or probably full advance. I disconnected the EST wire and it's at 10 degrees, plugged the wire back in and it went to around 5. What would or could cause it to lock in full timing like that? Any help is greatly appreciated.
Old Feb 2, 2002 | 11:52 PM
88TAJeff's Avatar
Car: 88 T/A
Was the car still running when you un-plugged/ plugged the EST wire back in? Before you plug the connector back in, you have to shut the car off if you want the computer to regain timing control.
Just something I found out. Was your advance at 36 deg at idle?
Old Feb 3, 2002 | 09:01 AM
JAY87GTA's Avatar
It was still running. I had set it all earlier in the day, drove down the road to several places, ya know visiting family ect. When I got back home and before I shut it off I whipped out the timing light. That's when it read 36 at idle. Is there a seperate EST module that controls the timing or is it all done by the computer? Thanks
Old Feb 3, 2002 | 09:40 AM
ede's Avatar
ede
the est is a seperate unit mounted on the firewall. your manual should have a pic or drawing with all the sensers located for you in the engine controls section.
Old Feb 3, 2002 | 01:43 PM
JAY87GTA's Avatar
Ah, Okay. If I shut it off the timing goes back to normal until I drive it again. Took me a while to track the problem down because of it, ya know how it is Thanks
Old Feb 4, 2002 | 04:54 PM
JAY87GTA's Avatar
All right, my Chilton's don't say crap about an EST module, at least I couldn't find it. How about Hayne's? Can anybody help me out. Thanks
Old Feb 4, 2002 | 05:05 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
go to helms.com and get the real book. Worth the 89 bucks in gold...
Steve
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
midge54
Jan 29, 2017 07:00 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirim
Aug 9, 2015 06:19 PM
