Can a Ford 19lb injector flow the same as a GM 22lb injector.....
Old Feb 3, 2002 | 11:23 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
with the Ford injector running at a higher pressure? Like around 46 or so???? I will be using them in an 1989 L98 350 Camaro. I cant find any reasonally prices 22lb injectors......the cheap accel's go from 21 and skip 22 and go to 23
Old Feb 3, 2002 | 11:50 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
In short...yes...but why not go with the 21 Accels, they'd be so close to what you want, you'd enever know the difference.
Old Feb 4, 2002 | 02:47 PM
Damon's Avatar
Yes, Ford rates their injectors at about 37 PSI, GM does it at 43 PSI. Ford injectors are the cheapest way to go that I have found in most cases as long as you just keep the different rating scheme in mind.
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
toronto formula
Sep 10, 2015 07:31 AM
Street Lethal
Sep 7, 2015 01:09 PM
