oil in the water:(
Old Feb 4, 2002 | 10:10 PM
craiger's Avatar
oil in the water:(
I can't firggin beleive it! I have 1000miles on my new engine, so i put the supercharger back on about 150 miles ago. Today, i jumped on it getting on the freeway and i blew a head gasket
I had to drive it about 3-4miles to get it home. It was running like crap! White smoke, the whole 9yards. Anyway, I spent a lot of cash on the engine, AFR heads, balanced and bluprinted shortblock.ect... Do you think my bottom end is ok? I am concerned about the antifreeze that was in teh oil. should I be ok?
Old Feb 4, 2002 | 10:12 PM
rezinn's Avatar
Um.. just don't drive it at all. Take it apart and check the damage. Most likely it will be fine if you didn't drive it more than a few miles.
Old Feb 4, 2002 | 11:10 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
And most importantly, REMOVE the oil/water combo you have in the crankcase immediatly.
The oil/water combo builds moisture and it will start forming rust in the crankcase.
The coolant is a corrosive when on the bearing surfaces so you want to remove the oil mix and repair ASAP to get new/good oil in the system.
Old Feb 4, 2002 | 11:49 PM
craiger's Avatar
I drained all of the water/oil out of the oil pan as soon as the car cooled off. I will not be able to put any oil in the car until wensday because i work tomorrow (24 hr shifts). will I be ok leaving the engine with no oil sitting in my garage?
Old Feb 4, 2002 | 11:59 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
yeh, thats cool...the important thing is to get the old stuff out.
I've left them with no oil in them for a week or 2 while fixing the problems.
Old Feb 5, 2002 | 01:05 AM
craiger's Avatar
Thanks for the help! I really appriciate it! This could not have come at a worse tiime! I have a huge job interview on friday and can not touch the car until i am finished with the job thing.
thanks again!
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
