Replacing lock cylinder...
Old Feb 9, 2002 | 03:25 PM
LottaBallsCamaro's Avatar
The 91 RS which has Vats. I've got it out but couldnt find any disconnect for the vats so I just cu them, Did I **** up? I know it measures resistnce but there wasnt any other way to do it. SO now I have both of my Camaros decommisioned right now, this sucks!
Old Feb 9, 2002 | 03:47 PM
bubbareno's Avatar
Car: black on red 92 rs
Transmission: t-5
lock cylinder
Hey whts up i jus did mine last week., there should be 2 little wires coming out the steering coulum than it plugs in too an orange wire writ next to the air bag wire, unplug it cut 4 inches back than take your old key an solder to the reistor on you key.
Old Feb 9, 2002 | 10:43 PM
Vader's Avatar
Sorry about the diagram size, but it is necessarily large for clarity:
Check item #20. There is a 5-6" pigtail on the lock cylinder with a connector that mates to a connector in the upper bowl of the steering column. Fish through the turn/hazard signal switch wiring and you should find the connector. The new lock cylinder should have the pigtail and connector as well, so if you cut the wires close to the lock cylinder, you should be O.K.
BTW - Them's pricey little thangs, ain't they?
Old Feb 10, 2002 | 02:07 AM
Good ***! It's a good thing I don't have dialup anymore! I saw that in my Chiltons but for some reason never accured to me. $51 from ACDELCO!
Old Feb 10, 2002 | 03:11 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
WOW!!! now I need a 60" monitor... I wonder if my local movie theater will put this up for me???
seriously... that stuff you have is great Vader...:hail:
zroc
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 21, 2015 01:54 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
