plenums-
Car: 89 IrocZ
Engine: L98-ish
In our situation (cars) pop your hood since you have TPI. See the long, squarish thing in between the tubes (runners) that go to the intake base? that's your plenum. It "holds" air and divides it to each cylinder through the runners.
When you "port it" you open up and smooth the transition points in it (at the runners and Throttle Body) to allow for more air to pass, and with less friction.
bamaboy0323
Aug 27, 2023 05:40 PM
