1966 Pontiac 326
Edelbrock RPM manifold #EDL-2156
Edelbrock 600 CFM carb Electric Choke #EDL-1604
I'm looking into a cam shaft now. I might just get the Edelbrock RPM one with .470 lifts and 231 int and 240 duration.
What do you guys think?
OR, to save like $100 bucks summit has one: .465 .488 ex and 114 duration.
What will happen with the WAY WAY WAY different durations? More midrange tourque? 231 and 240 compared to 114.
Take care,
Jon
Take care,
Jon
114* sounds more like a LSA (Lobe Separation Angle) Not a duration. I don't think it is the duration of the cam, considering it has that much lift and I've never heard of a cam that small. Check the numbers again. Also, is the duration for that RPM cam adv. or @.050?
i'd recomend the comp cams xe268h.
