How does this cam sound and what carb would be good???
Here is the cam specs:
CAM INT .310, LIFT EXH .325, VALVE INT .465, LIFT EXH .488, LOBE INT 107,
SAE DURATION= 298 INT, 304 EXH, .050 DURATION= 224 INT, 234 EXH
The cam is in a 70's 350 w/ 4-bolt mains and is punched 30 over.
The engine is going into a 86 camaro z-28 w/ a 3.73 posi and 5 speed. How does the cam sound for this setup? I am using the edelbrock rpm air gap intake as well. Also I was thinking with going with a edelbrock 750 cfm carb? How does this sound? any suggestions? any input would be great..
thanks a lot,
Dan
thanks a lot,
Dan
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Yeah, sounds about right. I'm getting the Comp Magnum cam that has a .470 lift and 270 duration. I've heard bad things about Crane so be careful. I'm building up my 70's (LM1) 350 on the tech/Gen engine board if you'd like to check it out.
-Matt
-Matt
Thanks for the replys guys..Someone had told me that there might not be enough vaccum for the power brakes with this cam..Is this true? If it is what can I do to possibly fix the problem?
Matt I will be checking out your 350 and good luck on it..
thanks,
Dan
thanks,
Dan
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
