Is your power steering hose giving you problems too?
Old Feb 12, 2002 | 06:54 PM
Hulk0202's Avatar
I have a 91 fb 305tbi. My power steering hose, the one with the sensor for the ac, keeps forming leaks where the metal and the rubber meet. I really have to contort the hose to make it fit right. Anyone else have this problem, and/or a solution. Thanks
Old Feb 13, 2002 | 09:49 AM
Vader's Avatar
Hulk,
If you have trouble getting a replacement hose to fit properly, consider making your own. Any good industrial supplier should have the hose and fittings you need, along with standpipes, swivels, etc. Select a hose that has a working pressure of 1,500 or more and is rated for hot oils. I've done this for oil coolers, transmission lines, and steering hoses with no problems. A custom steering hose is usually good for about twenty bucks.
Attached Thumbnails Is your power steering hose giving you problems too?-crimphose.jpg
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
