Lock cylinder and VATS related questions..
Old Feb 13, 2002 | 08:15 PM
breathment's Avatar
what makes the GTA lock cylinder different the the regular lock cylinder??? Is it because of VATS?? either way i went to autozone to pick up a lock cylinder and key. They gave me it, but it was missing something... (SEE PIC BELOW) So where DO i get a VATS lock cylinder? I would of thought the GTA that they gave me was with VATS because it cost me $60.. Oh well, gonna try the dealer tomorrow.
OH any my last question, is where is the VATS stuff located? like the resistor info and stuff. is each lock cylinder different?? or do i have to tell them the resistance of my current key?
Old Feb 13, 2002 | 09:29 PM
LottaBallsCamaro's Avatar
That is the right lock cylinder. the cylinder does not achually carry any of the VATS, just has the two wires that run through it to make a connection with the resistor in the key. You need to take that key with your existing key to the dealer and they will have a black box that will tell them which resistor to use. They will make a key with the new pattern and the resistor that was already used on the car. Its hard as a beotch to snake that wire back down the coulmn so when you pull the old wire up, have a string attached to it so you can snake the new one down there.
Old Feb 13, 2002 | 09:52 PM
breathment's Avatar
but i can't use that key and cylinder they gave me right??? since the key doesn't have the thingy?
Old Feb 13, 2002 | 09:55 PM
You have to get them to make you a new key with the "thingy"(resistor)that follows that patern, but the clyinder is the right one.
BTW- the new key will cost like $20.
Old Feb 13, 2002 | 10:44 PM
breathment's Avatar
ok, shouldn't be too hard.
ya i remember when i got the keys copied when i first got the car, i went to a key shop, and they did it for like $12.. so maybe ill try there before the dealer...
thanks alot..
db057
Apr 28, 2019 07:45 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
90formulaVortec
Sep 7, 2015 06:54 PM
