Starting And Fuel Problem Help!!!!!!!!!!!!!!
Old Feb 14, 2002 | 11:48 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
Yes this problem seems to be quite persistant. I try to go out in the morning and start it up. then it will crank over as long as the battery lasts without starting. but if I go out and play with the schroder valve on the fuel rail some air will come out like its pressurising air in the fuel rail. but if i turn it on and of just to run the pump and release the air and then crank it over it will start.
I do not understand please help me!!!!!!!!!!!
Old Feb 15, 2002 | 08:54 AM
Vader's Avatar
Eric,
You should get your hands on a fuel pressure gauge to help diagnose this situation. It's possible you have a fuel pump that is leaking back through its check valves, and you should test the pressure drop over time to help determine this.
Old Feb 15, 2002 | 11:29 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Yes, I seen it many times.
If you have a starting problem or a fuel problem, the first thing to check is the fuel pressure.
92camaroJoe
Jul 29, 2023 07:57 PM
bryan623
Mar 22, 2021 06:43 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
