Whats a 350 block/crank and factory heads worth?
Old Feb 15, 2002 | 03:51 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
I've got a 350 block and crank with the factory heads that came out of my '94 truck, all in good shape, would just need new rings and bearings to be used again, 2-bolt main, got swirl desing heads. Just wondering what the going price would be for all of it together may be.
Old Feb 15, 2002 | 04:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Swirl heads make good anchors.
Block maybe a couple hundred or better.
Say, my job may take me to Fort Worth one of these days soon - wanna hang on to it for me until I get there?
Old Feb 15, 2002 | 04:58 PM
94'_SS's Avatar
I am in the same boat I live about 1.5 hours away but dont have much money !
Old Feb 15, 2002 | 08:30 PM
2QUIK6's Avatar
Its just the block, crank, rods, pistons, and heads. It does still have the factory cam and lifters and springs, but would all need to be replaced. Its got just under 100k on it. If you want it for $200 its yours, let me know.
Old Feb 15, 2002 | 08:40 PM
GreenProStreet's Avatar
You guys that want it, it is a good block. I believe that the trucks are one-piece main seal, roller cam blocks. They work very well, especially in TPI situations. Make sure you sell the lifters and retainers with the block, because they are reusable, but should always stay with the block. If the block doesn't come with them it is a rip-off, at almost any price, because a new set of roller lifters will set you back more than a junkyard 350 will. I think that htey are only made by GM.
Old Feb 15, 2002 | 08:57 PM
2QUIK6's Avatar
It is the one piece rear main seal, has the provision for the roller lifter retainer but not drilled out as it does not have roller lifters. And roller lifters for a 350 can be purchased almost anywhere and are made by most manf, Comp, Crane etc...
BTW, I can get $100 core fee at the local remanf. engine block shop and that would be I'm sure very low $ from there..
Old Feb 15, 2002 | 10:25 PM
94'_SS's Avatar
Shoot me an e-mail with some more info such as is it complete what kind of cam is in it ect.... I am looking for an engine I can drop in my car run as long as it is in decent shape. I could swing 200 if I could drop it in and run it.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
