Part Number For K&N Filter That Goes Right On TB
Old Feb 16, 2002 | 08:11 PM
Bill Kirsch's Avatar
Hey guys,
Could someone point me in the right direction for the part number of the K&N Throttle Body Filter that bolts right on the Throttle Body?
It's not for my Camaros it's for my 85 Corvette, but you guys always help me out!
I'm switching to the TB Filter cuz there is a MSD 6AL where my old air box used to be
The TB is a Ling. 58MM if that makes a difference, but I think it's the same size air inlet adapter as stock..
Thanks in advance!
Bill
Old Feb 17, 2002 | 10:49 AM
Ok, What about if I wanted to put a K&N right on the Throttle Body of my 86 Camaro? Then would someone know where I can get one!
Come on guys! I know someone has one and knows the part number!
Bill
Old Feb 17, 2002 | 11:26 AM
morpwral's Avatar
Car: 82 Firebird SE
Engine: 350 CCC 4bbl
Axle/Gears: 10 Bolt, 3.23
I searched in my Jeg's catalog and the only one I found is labeled "cone air filter". The part numbers are "599-RC-5000 and 599-RC-5050". Air flow 600cfm, 1000cfm respectively. The reading states that it fits directly on the throttle body on speed density systems and will not fit LT1's. You could check their site with the numbers above to get a look at them yourself. Other mail order companies might have the same but at different prices and shipping costs. Check them out. Good luck.
Old Feb 17, 2002 | 12:45 PM
cort351w's Avatar
I have had both (and returned both). The RC-5050 is way too large to fit any thirdgen, don't waste your time buying it and taking it back. I am pretty sure that the RC-5000 will fit your Camaro--it fit onto the TB of my 91 Formula, but hit the hood when I closed it. Since the Camaro has a little more hood clearance, it should fit your car.
Old Feb 17, 2002 | 05:46 PM
Thanks guys!
That was the information I was looking for!
Bill
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
IrocZ'85
Aug 17, 2015 06:24 PM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
