Help! Ground Wire?
Old Feb 16, 2002 | 11:21 PM
craiger's Avatar
Help! Ground Wire?
This may sound like a stupid question, but here goes. Where does the battery ground wire run to? On my Z28, there is a small wire that runs off the ground cable by the battery terminal to the frame. where does the negitive end of the cable run to?
Old Feb 16, 2002 | 11:26 PM
Chevy83Z28's Avatar
The thinner part of the ground wire connects to the chassis/frame and the thicker part connects to the engine block (I think somewhere near the air pump.) Then there's also a braided strap connecting the engine block to the chassis (I think this is at the firewall.)
Old Feb 16, 2002 | 11:50 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Mine was bolted to the alternator. There is a place on the front of the alternator that is tapped, so you can just bolt in on.
Old Feb 17, 2002 | 01:00 AM
rezinn's Avatar
They are both right. On my 87 camaro it was originally bolted to the alternator, but after I swapped my accessories for serpentine the alternator moved, so I put it on the engine. The smaller wire always goes to the chassis.
Old Feb 18, 2002 | 08:52 AM
Chevy83Z28's Avatar
I also put in a battery w/ top and side posts and on the top post put a 4-gauge wire to the chassis for an extra ground.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
Glowsock
Aug 26, 2015 12:28 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
