HP at the flywheel
Old Feb 17, 2002 | 01:17 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
HP at the flywheel
How much horsepower does the 305 TPI have at the flywheel? My car is the 190 hp engine but is that at the wheels or the flywheel?
Old Feb 17, 2002 | 02:33 PM
Astro's Avatar
chances are you're running 190 at the flywheel. When dealers advertise HP they use the biggest number they can (flywheel HP) as this attracts unknowing buyers much easier. So you've most likely got 190 HP at the flywheel.
Old Feb 17, 2002 | 02:53 PM
Guest
Guest
Posts: n/a
None of the HP ratings you see from car manufacturers is RWHP, they are all measured out of the car on a stand, accessories and exhaust attached (since 197x).
Old Feb 17, 2002 | 04:54 PM
trans87's Avatar
Man, then I really need to start beefing the motor up I can't even imagine the power at the wheels then Oh well that will change then :lala:
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
