coil
Old Feb 17, 2002 | 06:30 PM
BamaZ28's Avatar
coil
how can u tell if a coil is bad??? is there any way to fix it??? my cars not firing... i've replaced plugs, wire, cap, and rotor.... any help would be greatly appreciated
Old Feb 17, 2002 | 08:18 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You can check the secondary resitance and primary resitance..if in spec, it should at least fire...Primary resistance should be minimal (I don't know the spec, would have to look it up...something like 1 or 2 ohms), the secondary resistance should be high..in the 6-10K range (just a guess, refer to a spec).
That said, do you have 12 volts on the coil when the key is on?
Old Feb 17, 2002 | 09:08 PM
BamaZ28's Avatar
coil
i haven't checked yet... ran out of daylight... i'm just now getting time to work on my car... but thanks for the info... i'll check asap...
Old Feb 17, 2002 | 10:10 PM
SoCo80p's Avatar
seldomly coils go bad, i've had ones 30 years old that work fine, check to make sure all the wires are hooked up and everything looks ok
Old Feb 18, 2002 | 09:29 AM
BamaZ28's Avatar
coil
it seems to look okay... any other suggestions on why my car isn't firing??? it was running and i played w/ the carb and it started running rough and has run since.. i can't figure it out... could it have jumped time?????
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Giocio
Oct 1, 2015 12:20 PM
