VIN number?
Old Feb 19, 2002 | 04:30 PM
Loki1199's Avatar
VIN number?
What can I learn frmo a VIN number? I just got a new 1986 T/A and I know it originally came with acarb and a 305. but I want to know what gears came stock, if it came stock with front and back disc brakes, etc. how can I find this stuff out?
Thanks!!
Old Feb 19, 2002 | 04:40 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The VIN won't tell you those kind of things. You need your RPO codes. Under the console lid, or in the hatch in the lock compartment. I believe there is a RPO decoder on the home page.
Old Feb 19, 2002 | 04:42 PM
Loki1199's Avatar
Those numbers are missing. The inside has been taken out of the lock box and the console. Where else can I find them?
Old Feb 19, 2002 | 07:41 PM
Car: 99 Formula
Axle/Gears: 342
OOH, that's a tricky one, if no one else helps out here, check the History/Restoration board.
Old Feb 20, 2002 | 08:44 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Just a thought, but didnt GM stamp the passenger side axle tube on these cars. If you can get the letter/number code off of it, I can decode it for you. I believe it should be on the forward part of the tube close to the middle of the rear end. Im sure youll have to scrape off some rust and/or grease to see it. But its there.
Old Feb 20, 2002 | 09:02 AM
Vader's Avatar
With rear disc brakes in 1986, you probably have a Borg-Warner rear axle (nine bolt cover?). There were only two axle ratios available in that housing in 1986, IIRC.
Old Feb 20, 2002 | 06:39 PM
1986redbird's Avatar
I think I read somewhere that they put the RPO code stickers on the inside of the armrests on the doors.(I THINK ????)
Linson
Oct 24, 2025 02:00 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
