Can I remove overflow tank??
Old Feb 21, 2002 | 12:19 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
I was wondering if I can take it out to free some room in my engine bay. On my 72 LeMans, i have a tube that runs down that allows access to drain onto the street. Can i just replace that tube with one of those???
Old Feb 21, 2002 | 05:48 PM
Vader's Avatar
RS89,
You can remove the overflow reservoir, but it is there to allow the system to refill after it has become hot. The system is designed to "respirate" a bit, and you may eventually lose coolant level without the overflow reservoir. You'd have to check the radiator regularly, and would likely have to maintain an air space in the radiator to prevent burping out of the coolant.
Old Feb 21, 2002 | 07:25 PM
rezinn's Avatar
If you ever plan on racing on a real track you must have an overflow tank.
1992 Trans Am
May 10, 2023 07:19 PM
Strick1
Aug 27, 2015 08:57 PM
Glowsock
Aug 26, 2015 12:28 AM
theurge
Aug 21, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
