Weird Vibration after mods
Old Feb 24, 2002 | 08:36 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Whats it like what a Harmoni cBalancer goes bad? after i basically swapped in everything brand new i get a vibration when i give it gas at idle. i put es motor mounts in new cam and heads. How do i know if the balancer is ok? I also put in a new converter. would it being loose on the flywheel cause vibration? i'm kinda lost. i bought a new streetdamper. Should I slap that on and try that? Also The timeing looks lost on the way the dis is set up. Timing is at 6* but how do i know if the outside ring slipped? Thanks
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
BWilcox
Sep 20, 2015 12:19 PM
