SLP Prom CLEARANCE
Old Feb 27, 2002 | 11:55 AM
Steve89GTA's Avatar
SLP Prom CLEARANCE
Hi Everyone,
I'm wondering if anyone has used SLP's proms. THey are on sale for $69.99. That's a considerable savings over Jet or Performance Resource.
Any thoughts on this product. THey don't specify TPI or TBI which scares me a little.
Thanks, S
Old Feb 27, 2002 | 11:57 AM
Steve89GTA's Avatar
Hmm...
Since I have a high flow cat and muffler..should I get the dual cat chip or the single CAT?? My car flows much better than stock through the exhaust.
Any thoughts?
Old Feb 27, 2002 | 01:20 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've got one for a 91 5 speed TPI. Bought it used so that I could use the whole module for a custom chip, paid $30 for it.
I did put it in my friends 91 Trans Am 383 and it made her car run pretty darn good, chip is for a 305 TPI 5 speed.
Old Feb 27, 2002 | 01:29 PM
Steve89GTA's Avatar
soo.....
So, it IS for the TPI then.
Part # 40026 is for single cat
Part # 40028 is for dual cat setup.
There are no 'stages' here like a Jet chip so I'm wondering if I should get the dual cat chip (even though I have a single high flow unit and high flow cat-back).
Do you think the dual cat chip would serve me better?
Thanks in advance.
S
Old Feb 27, 2002 | 01:31 PM
Steve89GTA's Avatar
CAM
2050 CAM
Hey, how do you like the 2050 CAM over stock?
PROS/CONS?
Old Feb 27, 2002 | 02:35 PM
Zepher's Avatar
Re: CAM
Originally posted by Steve89GTA
2050 CAM
PROS/CONS?
2050 is great, but you have to remember that I never had the TPI in the car with the stock LG4 cam. Almost all the parts on the car were put on at the same time so I Can' tmake any comparisons from stock to modified.
I can tell you that from the carb to TPI swap, the TPI is faster, runs better in all temps, and has a lot of torque.
If I can get everything square away with my car by the 22nd of March, I will see exactly where the car stands in the 1/4 mile.
I am hoping for low 14's, but I will be sooooooooooooo happy if I break into the 13's.
I should bring a helmet just in case.
Old Feb 27, 2002 | 05:41 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
if your car came with the single cat, get the single cat chip.
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
Dragonsys
Sep 25, 2015 03:51 PM
