compression
Old Feb 28, 2002 | 08:03 AM
joemo22's Avatar
Car: 1989 Camaro
Engine: 383
compression
I have a 350 block that I am building and I was wondering what is the highest compression I can run with the block.
I wanted 11 or 12 to 1 but someone told me that I could not fill up at a gas station because I would need higher octane.
Old Feb 28, 2002 | 08:37 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Your friend is right 12 to 1 equals race gas. The general rule is 9.5 for iron heads and slightly higher with aluminum heads. I am running 9.5 with a mild timing curve ( bout 32 totoal timing) and i can get away with 89 on a good day but it really likes 93.
Old Feb 28, 2002 | 10:48 AM
Vader's Avatar
With adequate head cooling and enough EGR at the appropriate times, I can run 10.8:1 on 93 octane (gasohol) without a problem or severe retard from the PCM. This is with 54cc iron heads, BTW.
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
