roller cam conversion
Old Mar 2, 2002 | 11:26 AM
'86tranzsheezam's Avatar
roller cam conversion question
Anyone know for sure whether or not the factory late model roller cam components (lifters, spider etc) can be used to convert old style 350 block ( 68 model)? I've heard both that it can and cannot. I've got a factory steel crank, pink rods and a couple of usable old style blocks but don't care to spend a fortune converting to roller. Any advice would be greatly appreciated
Old Mar 2, 2002 | 11:54 AM
Stroked-Z's Avatar
You cannot use the OEM roller lifters in the older style block.
What i would do is get a retro-fit kit from a reliable manufacturer (Comp, Crane, ect...) It will come with all the stuff you need such as stiffer springs for your heads, cam button, retro-fit lifters, cam, timing chain, ect....
It will also give you peice of mind.
Old Mar 2, 2002 | 04:56 PM
Thanks for the info, I didn't think they would but I've heard some say you can. Guess I'll just have to spend a little more cash
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
