Is a siezed block reuseable?
Old Mar 2, 2002 | 09:53 PM
Xenodrgn's Avatar
A guy at work has a seized 350 block out of an early 80's vette in his garage. Would it be worth it to offer him a couple of bucks for it and try to build a reliable engine with it? Or should I just stick with a block that ran.
I would assume it would be fine with a reboring (assuming the block isn't cracked), but you guys know more than I do.
Old Mar 2, 2002 | 10:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Offer him $50 on the condition that the block is rebuildable, $75 if the crank & rods can be used as well. If not, you're providing him with free removal service.
Old Mar 3, 2002 | 03:07 AM
ronterry's Avatar
Car: '94 Corvette
also, just say no if a rod is hanging out the side of the block.
If it's siezed then 9 times out of 10 the crank is probably shot cause it spun a bearing. It does'nt take much for a rod to eat the crank up, but the block is more then usable...however if he droped a valve, then that's pure evil for what it does to the cylinder.
Ron
Old Mar 3, 2002 | 11:01 AM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: Is a siezed block reuseable?
If it ran when he took it out, it can be used as long as it didn't sit with water in the bores. I purchased a pontiac 400 from a fellow, been sitting in a barn all apart for years. The block took +.030 and the crank could have gone std. but I had it turned -.010. Ask him why it was taken out. You may have just found a good block and crank.
Old Mar 3, 2002 | 02:03 PM
Xenodrgn's Avatar
A guy at work has a seized 350 block.
Hence the reason why he took it out... it froze up...
I'll offer him a few bucks for it... it's been sitting for close to 19 years now, I guess he's not doing anything with it.
If I do get it... I'll have it checked and worked at a machinist... and then use it for a project motor... if I do get it, it'll have a 350 turbo trans behind it, a street friendly cam, probably Vortec heads and a carb... nothing special... just an uncorked and smooth running 350...
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
